    TIPS:
Reptile pcm tuned 90 shipped
Status
Not open for further replies.
stlunatics2oo3
I bought a pcm from reptile on here and it wont work on my monte carlo, so as I've talked to him he said if i sell it and i can send the pcm to him to be tuned for someones else GP for cost of shipping, so I will sell this for 90 shipped and I will cover shipping the pcm to him and then him sending to you.
Re: Reptile pcm tuned 120 shipped
he dont have the pcm anymore I bought the last one, your basically paying for shipping from me to him and him to whoever buys it, its or best..
it will be for your year and what reptile tunes usually are, pretty much like zzp but his own twist.
For 98-02 GT/GTP's
Speed limiter removed
Raised rev limiter
Raised shift points
3-1 and 4-2 skip shifts (Removes "40MPH WOT lag")
Programmed for race pellet added timing
Transmission line pressure increased
185F fan turn on
90 second fan on at key-off (when engine coolant is 180 degrees or greater)
MAF calibration is year specific (please make sure that I know what MAF you do have.)
PE tables enriched to reduce KR
Part throttle KR issue fixed
Torque abuse modes are modified to eliminate bog at launch
I can let them go for $125 shipped to your door. There is no core, you don't need to send your old one back to me, HOWEVER, I will buy your stock one back for $25 if you don't want it. Keep in mind, that you WILLneed a CASE learn once you put this in. This cannot be stressed enough. You can't simply put this in, and take it to the track to flog on it. It needs to be treated lightly until the learn is done, and then put a few good decent miles on it.
Anybody that's gotten one from me over the last few years knows that they're getting a good quality, and that I'm easy to deal with. Shipping out of the KC area, so if you are close, I can even meet up.
I have a 97 GTP(my red one) and a 98 GTP (my dad's) . I need it for the 98
then it will work for it, it says 98-02 GT/GTPS, Im waiting for reptiles response on the evap code and egr code removal.
Status
