reprogramming keyless entry
kulieboy
does any one have any idea about the key less entry. I have tried every way non to man and they still dont work.
My car is a 2000 gtp I have tried the programming as of sitting in the car pulling the fuse, cycle the key to acc then off and back to acc, open the drivers door close the door and you hear a chime or the seat belt light flashes 3 times. I hear or dont see anything. So that tells me that its not going into reprogramming mode
[FONT=verdana, arial, sans-serif]uoir directions should be something like this. acc means turning the key backwards. it moves a small click and the radio and stuff works. [/FONT]
[FONT=verdana, arial, sans-serif]Sit in the vehicle driver's seat. [/FONT]
Remove the ignition key from the ignition
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Remove the ignition key from the ignition lock cylinder.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation .
