since the gtp's sitting for the time being, i was thinking about replacing as well as upgrading the radiator since it has ~160K miles on it and i read horror stories of where the tranny cooling lines running through the radiator leaks and gets contaminated with coolant and FUBARs the tranny itself. now i also read about the different size radiators that the 97-03 w-bodies can use over the stock 5/8"(that is stock core thickness right?).
my local pepboys i had the tech guy look up the radiator for the 98 chevy monte carlo v6's and he has one that has the following measurements: 30-1/2"x15"x1-3/8" for $139.99 w/lifetime replacement warranty. i measured the core thjickness itself and it was between 1-1/4" to 1-3/8". i skimmed through the How To section found rad upgrade. aside from the fan clearance and the longer bolts needed, is there anything i should know and get the proper pieces b4 i would tackle this mod?
