Replacing suspension
zildjian102
Okay well i need to replace the struts, springs, sway bar, and whatever is involved with replacing handling parts. Ive browsed around the forum but nothing totally answered my question..
I want to know:
What are ALL the parts that i will need to complete this and I want a little bit lower ride hight but not by much.. vogtland springs?
For just a slight drop, yes, vogtland springs are the ticket. For a list of parts, just going off the top of my head:
  • Springs
  • Struts
  • Strut Mounts
  • Sway Bar, Front & Rear
  • Sway Bar Bushings
  • Lateral Arms
  • Strut Tower Braces
  • Trailing Arms
  • Sway Bar Endlinks
  • Control Arms
  • Control Arm Bushings
  • Ball Joints
  • Tie Rod Ends, Inner & Outer
And I'm sure there is a lot of little stuff to go along with that list. But it is pretty complete.
I usally check on this GM site for diagrams and some of there parts are cheap. They used to carry the Koni strut kits, handling kit, and brake upgrades but I believe they are discontinued.
GM Alternate Parts Catalog
1) HUB and BEARING2) KNUCKLE3) STRUT4) SPRING SEAT5) LOWER SPRING INSULATOR6) UPPER SPRING INSULATOR7) COIL SPRING8) SHIELD9) BUMPER10) STRUT MOUNT11) LOWER CONTROL ARM12) BUSHINGS13) LOWER BALL JOINT14) STABILIZER BAR15) BUSHINGS16) BRACKET17) LINK
