replacing my trans - what else when I'm there?
SJAndrew
I'm getting a TEP rebuilt unit in the next month or so. I will be dropping iot from below.
Dave mentioned replacing my radiator (due to potentially clogged trans cooler).
What else should I do when I'm "there"?
I would highly recommend using an aftemarket trans cooler and just bypass the radiator cooler. Dave is right in his concern, and no amount of flushing with not so cheap trans fluid will guarantee no contaminants. Mounts also come to mind if you have it down, much easier to replace them like that. Maybe plugs too since from underneath, with no trans, should be easy to get to the back ones.
