Replacing LIM and UIM gaskets, 2004 GTP
koaa0601
Hello,
Im going to be replacing the lower and upper intake manifold gaskets soon, They are leaking coolant everywhere. My question is what else would be a good idea to replace while I have the intake manifold and supercharger off.
Hopefully you didn't see Brians unreasonable answer before I removed it.
Gaskets/things to do while you are there.
New set of coolant elbows (Dorman 47065)
Fresh TB gasket
Check/replace any old/bad vacuum lines
New fuel injector o-rings (es70599 need 3 packs)
If your valve covers are leaking, it's also much easier to do them with everything off.
