replacing bumper cover
jspangler22
my new bumper cover is on the way. How easy is it to replace? Also anyone knows any good sites for me to paint it. Its already primed so i should probably just wetsand with 1000 grit spray my black maybe wetsand again spray and the wait how long to clear it? then wetsand clear and polish it
it is very easy to replace man. Open your hood and rigth above the grills u will see 3 push pins. Snap those out. Then look in the fenderwell u will see 1 bolt holding the bumper to the fender. and liek 3 screws on each side holding it to the fenderwell. And dont forget to unplug your fog light bulbs or take your fogligths out before you do it
sounds good the fiberglass is so busted up on the one on it now. Hipefully plastic holds up better. I couldn even put my new lower grills in yet
The only tricky part is you will see like a while triangle inside the fender, that doesnt come off. the bumper slides out forward. also there are like 8 push pins in the lower facia if its a GT/GTP bumper.
