replacing alternator
jbizach
Hey guys i need a little help im about to replace my alternator and im not sure on how to release the tenson from the belt. I know thers a blet tensioner just not sure how to or wat bolt to loosen to get the tesioner to let some slack. any help wopuld be awsome.
98 gp 3800 n/a
you don't loosen anything. Get a 15mm socket on your breaker bar on the tensioner bolt and pull back (if i remember correctly, if not just do it the other way) these tensioners are spring loaded.
Yeah, it is the pulley under the alt. IIRC...and you push the 15mm wrench or breaker bar towards the firewall...
