99GT2dr
So I bricked the original PCM in the regal, started with a partial write, got an error message, tried doing a full write to fix it with no luck. So I got the numbers off the pcm, and grabbed a suitable replacement off ebay. Install the PCM, reinstall all my powrtuner stuff on the laptop (1.1 framework, 1.2.4, etc), connect the laptop up and I'm able to do a full write no problem. Wrote the same file I'd been using (did a read on the original PCM, and made all my modifications to that file) that I've never had any issues with, and now the car dies after about 3 seconds. Starts right back up every time, and dies again. Tried writing a '98 GTP file, but that was a no-go (wouldn't even crank). Not the fp resistor (I checked it just in case, though I found it hard to believe it would go bad just sitting for a few days waiting for the new PCM to arrive, both by bypassing it and plugging another resistor in).
Mechanically, no issues with the car, I'm sure this is somehow PCM or file related, or maybe security related. I tried doing the vats relearn procedure with no luck, resetting the passlock with no luck, writing an original '98 GS file from Bill's dropbox with only the IFR/injector skew changed for the 42's and E85, and nothing. WTF am I missing here? I've gone through the file I've been using forever, found nothing off, disabled VTD, disabled flash security, re-enabled both after disabling had no effect. I replaced the PCM in my 'bonne (and running a '98 .bin on a '99 even), and had none of these problems, started right up. Is there something I don't know about the Buick security system that's doing this? I thought the VATS stopped it from cranking, not killing the fuel after it was already running. Thanks in advance for any suggestions.
