Hi,
I replaced my broken forward clutch band (4T65E, in car replacement), took it for a drive and everything seemed to work great. I could hear it shifting through all of the gears, etc. I went to test manual shifting and the lever would not go to 3rd. Then realized it wouldn't go into neutral or anything else. Couldn't find a cliff to drive it off of, so just drove home depressed.
Popped the shifter cable off and it moves fine, but the transmission gear selector is locked up hard. Took the whole thing back apart (up to the trans side cover) and it looks like there is a long rod that goes from the selector mechanism clear to the back of the transmission. I didn't remove this rod and don't remember doing anything with it, but it seems to be the problem. At least from what I can tell so far. I'm fine with taking everything back apart, but I don't know what I did wrong, so I'm sure I would make the same mistake again. Any ideas what is causing this problem, or what I missed?
Sorry to bug everyone with such a vague question. It's pretty clear I shouldn't have gotten into this repair, but I'm kind of stuck now.
Thanks
Thanks
