reomve or keep 4" speakers in rear deck?
Slueth66
Im planning on running a 4 channel amp to the rear and front, but not sure if i should just leave the 4 inch speakers installed and not powered, or remove them? I have read something about it creating a bandpass like enclosure, but am still not sure if that would be a good thing or bad thing.
are you upgrading the other speakers? or just powering the stock ones? and are you running subs? If you have subs in the trunk, and you are not "using" the 4" speakers take them out, it will sound good for the subs. the same as if you open the center pass thru in your seat
Thanks for the help guys. I replaced all the stock speakers with infinites, so i will just remove the 4" ones and try to sell them. Be kinda pointless to buy another amp just to power them. Im also running 1 rockford fosgate p3 in a qlogic type 2 sealed box at 500rms @ 2 ohms but sounds kinda weak, probably because of my cheap kenwood amp that i had to fix a few times, but hey, it was FREE
lol, I have about $900 into my setup, and thats including the $600 dvd player, oh, I forgot my wires and cap, so ya maby $1000. and this setup is running about 133 db
Mach5audio!!! ha, My old nabour sells them, he set up a ford f-250 ext-cab with 8 12's and a buttload of components, it is sick!
