removing the Grand Prix tags
PNIGZ
I have to do some body work and need to remove the Grand Prix tag off the trunk of my 00 gt what is the best way to do this.
Thanks
Use some fishing line to get behind the badge and work it back and forth. That will cut through the adhesive. After you get that off, use some goo gone or a similar product to remove any remaining adhesive. Then wash it off and give it a coat of wax and you should be good.
Same here...
Put some goo gone on the adhesive part of the badge while its still on the car, let it set for 5 min (makes it a little easier), then go at it with the fishing line, I used dental floss.
