removing emissions
z3r0
i found out my car has cal emissions, i live in fl where there's nothing. is there a write up on how to remove everything? i did search and found a reference to a post in 08 but no dice
Ok, so you know it has cal. emissions equip. Now we need to know the year and model of your car as it may vary. Is it a SE, GT, or GTP?
Just remove the evap canister and egr. You need to block off the rear manifold egr hole with something and the EGR hole on the LIM.
What are you doing to the car that you need to remove emissions equipment?
The EGR is a good thing for a daily driver. Not sure about how the AIR system, helps or hurts performance, though.
I am in daytona send me a PM and we can set it all up. i have a tuner and i can turn off the codes for you. and give you some tuning while at it!
