Removing center panel.
Godfather
What's the best way at removing the center panel? (07 GXP) need to get behind there to check bulbs/wires for cd/temp
I don't know alot about the GXP's but they should be the same as mine which is four bolts, 2 on each side down by the seats. Then you have to put your car into 2nd and then just lift up because it is held into place by a couple of clips.
