Linebacker
my battery needs to be replaced, i picked up a new one but i cant get the old one out, I unbolted the battery cables and released the battery clamp bolt at the bottom, i removed the bracing bar that goes to the strut. Now it appears this whole fuse box is in the way, I unbolted the two top bolts that go into the strut, popped the cover off, There is 4 bolts in a vertical line... do i remove those to get this fuse box out of the way? i have never seen such a ridiculous design. So if someone could give me some directions that would be great
And by the way, Its -40F where i am, so i can only work outside in 2-4 min at a time, Also if there is any plastic clamps holding that fuse box on they will break if i bend them at all...
