Remove Headlamp assembly?
roboz
i have 1996 4dr SE 3100
I was wondering how exactly to remove the headlamp assembly, or if there is a way to get to the 194 sized axillary bulbs within the headlamp, i had a few ideas with LEDs as well as some other modifications and restoring the lamps.
I also found a neat link for DIY halo lights i may look into on youtube. I haven't been able to find a writeup about this, or it is more simple than i realize.
An idea i had for my headlamps is replace the not so bright glowing auxiliary bulbs inside the headlamps with UV 194 bulbs of some sort. There is a special spray paint that is sprayed clear but reacts to ultra violet light and i thought this could look pretty unique having the headlight cover glowing if done right
thanks in advance
-Rob
