grandamle91
I'm trying to program my new remote and cant get it to.
1. Remove the key from the ignition.
2. Close all doors.
3. Remove the "MALL PGM" fuse from the fuse panel. Use the legend on the fuse panel or
owner's manual to properly locate the "MALL PGM" fuse.
4. Insert the key into the ignition, and turn to the ACC position.
5. Turn the key to OFF and then back to ACC within 1 second.
Cars beeping during this step too
6. Open and close any vehicle door. A chime will be heard when the system enters into
programming mode.
After this step the car keeps beeping
7. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
IMPORTANT: After 7 seconds, a chime may be heard confirming successful
synchronization. It is necessary to wait approximately 14 seconds for a second chime
that will confirm successful programming.
8. Repeat step 7 now for each additional remotes to be programmed including any existing
remotes.
9. Remove key from ignition.
10. Install the "MALL PGM" fuse back into the fuse panel and test remote(s).
2. Close all doors.
programming mode.
remotes.
