Reduced Engine Power/Service Traction Control
SteveNMe
I check through some of the previous thread and they seem kind of similar but not close enough to my specific issue. 2004 Pontiac Grand Prix. Have a current code of P0420 which I know indicates a potential catalytic converter problem. Replaced both O2 sensors, code still displays. Driving home last night (through hard rain), stopped at a red light and reduced engine power light and charging system failure light came on and the car shuts off. Couldn't get it to crank so I had it towed home. Was able to start it and pull is halfway into drive before it cut off again. Now I can get it to crank but it will cut right back off with the same codes and now the service traction control message is also on. Could all that be caused by a faulty catalytic converter? Am planning on replacement but was looking for a reliable person to do it in my area as I'm not familiar with anyone here as of yet. Any help appreciated. Also am taking my battery to autozone to be tested just in case.
Well, hard to say what your issues are. But yes, a clogged cat can cause a car to not run at all or run bad. If your cat has never been changed, I would say just do it. These things only last about 120k, more or less. They aren’t expensive; just have a local muffler shop weld in a universal cat. It is much cheaper than buying a whole new assembly.
The potential electrical problem, I guess the battery is a good place to start. I’d have your alternator checked also. But who knows, you might just have just dowsed something in the rain.
Thanks! I appreciate the feed back. Was hoping the rain and driving through a puddle would have been the issue but it sat overnight and hasn't rained in at least 12 hours so I'm thinking not now. However, I appreciate the feed back, sounds like we may possibly be on the right road.
