Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
GT997
Do I use red or blue threadlocker when reinstalling the three front axle hub bearing mounting bolts? Thanks!
[never use red unless it is for permanent install, you need heat to remove it if using red threadlocker
QUOTE=GT997;712378]Do I use red or blue threadlocker when reinstalling the three front axle hub bearing mounting bolts? Thanks![/QUOTE]
Red is pretty much permanent. Torque it right and forget it. You WILL be replacing your hubs again, anyway, might as well not make it impossible on your self.
