silenthaven
Red Interior lighting not working no other electrical problems. Dashlights out center console lights out and the side panel button lights all not working. Did a fuse blow? I've been checking fuses. Help!
Remove that POS. I had one for a few months and it cooked my battery.I was using a volt booster from zzp.....
Of course not. Those things create more problems than they are worth. Removing it just prevented future problems.removed but didnt fix the problem.
Check the dome light fuse. Next step would be to check for power; at the headlight switch, at the fuse etc. You have described that parts of two different circuits are faulty, so you will need to do some testing.is there a bad fuse?
