    TIPS:
red anodize Meziere Enterprises Electric Water Pump
Spartan GL
Specialist Walter US Army
Add some Bling to your engine. $250 Shipped in the United States.
The Meziere electric water pump will reduce operating temperature of your engine during idle, stop and go traffic, and general in city driving.
Highway operating temps will be similar to stock. At the same time it will free up approx 7 engine HP at 6k rpm. Dyno gains compared to stock begin around 4k rpm and will increase as your RPM goes up. This means that gains will be increased on cars with raised rev limiters and shift points over the 7HP advertised.
Perhaps the best feature of this kit for racing is track cool down. Run the pump with the car off and cool your engine down close to ambient within minutes!
Optional relay harness from Easy Performance allows simple installation and runs the pump anytime the ignition is on. Harness includes a second connection which will run the pump anytime the fans are running. This means that your existing ZZP fan switch will now run the water pump and the fans while the car is off. Using the optional 2nd connection on the EP harness your DHP PCM will run the pump for 2 minutes with the fans after you turn the car off.
Included:
  • One piece Meziere electric WP
  • Gasket
  • Meziere decal
  • Tech Edge plug and play harness
  • Installation instructions
Features:
-Fully CNC machined from 6061-T6 aluminum
-Works with GM Dexcool
-Efficient direct drive electric motor draws only 9 amps
-Light weight. Complete unit weighs only 4.3 pounds
-Available in polished, gloss black anodize or red anodize
-Retains all factory features such as heater setup
-35 GPM free flowing rating, or 42 GPM for the HD version
-Suitable for street use - 2500 hour life expectancy (about 100k miles of typical driving)
In this pic we are comparing factory pump vanes to the Meziere vanes. You can see the Meziere has CNC machined vanes over 3 times the size of factory vanes. This is the key to greatly improved cooling performance at low engine speeds.
ZZPerformance was the first to offer an electric WP for the Series II 3800 engine.
Some colors or variations could be drop shipped from the manufacturer.
Water Pump: 132 in/lbs + 80 degrees
http://zzperformance.com/3800/electric-water-pump.html
That's a good price on a reliable pump! Had one in my Mach 1 and I definitely felt it after install.
