Rear Wheel Hub Compatibility Question
99XC600
Quick question.
Are the rear wheel hubs for a 2004 GT1 without ABS the same as the hubs with ABS. Yes, I know one has the ABS sensor and the other does not. But I was wondering if you can use the ABS hub?
Reason being is I can get a good deal on a set of ABS hubs (New) For the same price as a single non ABS hub. Yes I know, it doesn't make sense to me either. The ABS hubs should be more expensive.
exactly the same.
Does your gp have no abs?
Yes, I have a 2004 GT1. No ABS at all. I've had several occasions where I've had to lock it up on the highway that I travel every day. It's not fun. LOL
I just want to make sure they would physically fit in the carrier. Pretty sure that they will.
Yes, they will. the only advice I have is to make sure to get good SKF brand hubs, otherwise you will be re-doing the same job in under 20k miles.
