Alright guys I've had enough of this WBS spring (OLDS INTRIGUE springs) bullsh!t.... the spring is so compressed the coils are rubbing against one another and one side is damn near 1" lower than the other (the spring is sitting properly on the isolator and everything seems like it's mounted correctly)... What other rear spring choices do I have (other than putting on the vogtland rears or putting the oe back on)? I want the rear to be as stiff as possible and would like the rear to be higher than the front (a little higher than OE)... WBS told me that "their" spring is approximately 350#, only other spring rate that I see close to that for our cars is ebay' DNAs which are 350#s but they're a lowering spring... any suggestions guys?
Oh btw I'm running an addco 22 mm bar already so don't tell me to run a thicker rear bar to increase roll stiffness pls
Thanks
Thanks
