Rear Speakers 2004 GTP
Status
Not open for further replies.
DeFe220
I have the Monsoon Radio with the in dash 6 cd player...
I have one blown speaker but have no clue how to remove it from its mount...(From inside the trunk or back seat...) If anyone could help it would be greatly appreciated.
Also because of the rattle the speaker was making, I unplugged the wire and the check engine light came on...but after I plugged it back in it would not turn off. Any ideas?
Thanks
to get to the speakers in the back deck your going to have to remove the back seat...only way to get to them and not break anything.
-reach under the front edge of the bottom seat cushion and there is two release tabs one on each side remove the lower cushion.
-the back cushion is bolted down, all the bolts on the bottom need to be removed and then lift the back out.
-the back cover plate has to be unbolted and then the rear deck cover will come off and then your sperakers are there
the light thing i have no clue
Status
