Rear door lights
BuckyKatt
Probably first in a series...
Recently, I added a '99 Grand Prix GTP to the collection.
I had to fix up the rear doors... and I noticed that the lights weren't hooked up. Then I noticed the front door lights work.
Oddly, there don't seem to be any wiring harness to the rear lights. In either door. I don't think that the doors were replaced.
Is this usual for the fronts to light, but not the rears?!? Where in the door would the harness be? I'm seeing the harness split into the lock, window and window switch. Maybe I'm missing the branch to the light.
Thanks.
BK
My 99 is the same. You can extend the wiring from the front doors if you want to wire up the rears. You will also need the metal contacts that are on the front reflectors where the bulbs make cotnact. My brothers 03 has no lights in the front or rear.
