Rear deck speaker install
jtackerman28
So I found some descent 6*9 pioneer speakers in the jy and picked them up, how do i get the old speakers out and the new in? I looked at one in the junk yard and saw how to remove the speakers but how do i get the plastic cover off without breaking it
The seat bottom should just pop loose. IIRC you push back on it from the front edge and pull up but it's been awhile since I had mine out. The seat back has to have the seatbelt bolts removed. IIRC there are a torx bit (T-45 or 50).
4 bolts... seat belt bolts and two smallers nuts. you will see them after you remove the bottom seat
