97RS
hey guys as u all know i have a 97 camaro 5 speed with a l32 engine and blower with a 97 gtp l67 pcm, injections and map and tb. im about to get a tune but i notice im having a problem that happens about once a day since i put it togeather. when im driving and i put the car in neautrual it just shuts off and it only happens like once a day when coasting. if i disconnect the mas air flow sensor the idle goes up and down like 300 rpms and never evens out. the map sensor im using is a brand new ac delco map sensor for a 97 gtp and i had to cut my na pig tail and install the new pig tail thats for the 2 bar 97 gtp sensor. what do you guys think it is no check engine cods other then automatic transmission codes. and sometimes i get a p0000 code. u guys think maybe its the added volume of air in the intake between the supercharger and the tb i had to do to make the supercharger fit? thanks for the help guys
