ok, i really need some info. my father in law brought his 2000 Grand Prix over, with random Misfire Cylinder One. i also have a 2000 Grand Prix GTP. on His grand prix, we changed the plugs/wires and 1/4 coil. still misfire cylinder 1. so i swapped plugs around within the car, still misfire 1, changed the #1 plug wire with one from my GTP, same issue. Swapped the 1 and 3 injector to see if it would follow the injector, it stayed with Cylinder 1 misfire. checked the part numbers and the ignition control modual under the coils was teh same, so swapped them between cars, same issue. he drove the car yesterday morning for 15mns, said it drove perfect, then when he stopped it started running rough. any idea what it could be? we've done plugs/wires/coil/ig. modual/injectors, nothing has worked! ive never had a misfire like this before. any info is greatly appreciated.
