question for you guys.
just did a brake job on a very limited budge.... I spent $40 and got rotors and pads. But here is the kicker the rotors where the best they had in stock and the pads are EBC red stuff. Also got the hardware ie clips and boots. the only thing I havent changed out is the bolts on the caliper and the caliper.
the reason the pads were almost new used for 6 months but they turned the rotors before I got the car and messed them up so it vibrated while braking. Also when going under 20 mph there was and still is a random rubbing coming from the brake some times it trips the ABS light.
Do you think its just the bolts that need to be cleaned and or replace or....Do you think its the caliper
if I have to replace the calipers I am going to upgrade to the 12'' from ZZP
please let me know I got a 1300 mile drive coming up in 2 weeks then another 1300 home after a week and a half..
Thanks for your input
