Ran a 12.3 @110 (Do i go smaller pulley?)
PWNED
Ran my best of 12.3 @ 110 last night with hoosiers and I love them! I feel the car is limited as I will get some KR with 93 and a bottle of boostane 116. When I go to the track I will add another bottle and get no KR at all. Rather do this than lower timing. With that if I reset the trims I will be an 11.8 afr like last night but after a week it will trim it self back to a 11.5 afr. Now I know the m90 is not very efficient after a 2.8. IS it really worth it to drop to a 2.7 or 2.6? Rather than find a ported gen 5 and adapter in 3 weeks before the track closes. The car is pretty stripped and weights 3375.
https://www.youtube.com/watch?v=3yH80HMLQeo
meth would let you run more timing. seems like we got the same set up other then you have a cam, i got rockers, im at 21º wot with meth.
Nice times.
What are you running for timing? You might gain more by advancing it on 93 octane versus dropping a pulley.
Missed that. Are you running qtp's? Your 60ft definitely has room to improve. You've got an 11 second car there with some tweaks.
You should advance timing to around 19° if you can run that much without kr.
Get that 60ft into the 1.7's. Cable the rear and let air out so you aren't spinning. You'll be really close to 11's.
A month ago when I ran a 12.7 @109 I was trying an 11.5 afr and 17* of timing and I got some KR but it was not my best run as the trap suffered a tad. I will try and go 17* of timing and see how it goes. I am really looking for another 12.3 or 12.2 pass in the next 3 weeks before the track closes.
If you aren't traction limited, a smaller pulley will decrease your 60ft. That will usually help your 1/4 mile time more than a few extra hp from timing.
The video is above for perspective on my launches. I know a smaller pulley will need a tweak in the tune as it is making more air.
I went to check my gen3 and I don't have a machined snout so I am stuck with the 2.8 unless I buy the machine tool. I will try another * of timing to see what happens. I am shifting at 6200rpm. I looked at my dyno sheet and it says no more power is made after 6k but per zzp it says power is made to 6200.
im on a stock cam, but tried shifting at 6200, rockers and springs, the time spent spinning just rpms and no power slowed me down. backed em down to 5800 and went faster.
I am going to try and attach my dyno sheet as the thumbnail will not let me anymore or delete for some reason.
