Quick! Radiator Drain Plug
Pontiac Racer
Where is it and how do you go about removing it. Also I took the 3 bolts holding the splash shield down and still won't come off. What do I do?
Is the drain plug metal or plastic? If it's metal it may need some penetrating oil on it to help loosen it up a bit.
Don't mess with the petcock. It's plastic. On the drivers side bottom corner. Just pull the lower hose. Quicker. Are you taking about the lower air dam?
X2 on dont touch it. Disconnect your lower radiator hose at the rad. You'll end up breaking the radiator before you get the drain open.
I went ahead and took the upper hose off. What a complete disaster. Coolant didn't flow out of upper hose. Took thermostat housing off and the coolant came out from there. Not what I was expecting. Said screw it and put everything together. Again with my luck, something HAD to go wrong. It's going in on Monday to get flushed cause I didnt' have any DEX-COOL so I had to fill it mostly with water. No driving for long periods until it gets flushed.
Of course fluid won't come out of the upper hose. That's gravity, hence pulling the lower hose. I hope you don't drive too far now that you have introduced air into the cooling system.
Yeah. Just a cramp trying to open with a thumb, finger and a bent arm. I even have spare ones from who knows where but I found some.
how to flush coolant.
remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.
then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
put your t stat back in, with new gasket, the upper hose back on.
now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
done.
done.
I took the upper hose off, but it didn't come out from there. That's what got me. The upper hose returns coolant from the block so therefore removing it would do nothing. It all came out from the thermostat hole. Stuff was dripping on the headers and burning and getting all over the ground. Had I took the lower hose off, I would've had success, but I got frustrated and said "I'm done!" I won't mind a shop flushing it cause I have all the parts, all they need to do is flush it.
done.
i bolded what your missing.
Ohhhhhhh from the radiator. Didn't fully comprehend it. Makes more sense now. Sorry 'bout that. Taking the hose clamp off the radiator seemed tricky cause it was pretty well hidden under everything.
Oh and I did remove the thermostat.
Lesson learned. I had in my mind the entire time from the thermostat side. After a failed attempt and like 3 hours to think about it, I found out that it wouldn't work. Stupid me!
you can leave the t stat in, nothing will come out till its 195 degrees, then it will puke some out and stop, and then repeat. aka a waste of time.
This is why I don't do my own repairs. Because I always mess something up and don't realize until after what my mistake was. I want to go into this profession, but don't have any useful skills yet lol.
part of learning is what not to do along the way, you wont do that twice lol we all f up stuff.
i got one friend i cant let him take a nut or bolt off or on. he's either got the ratchet set to tighten and then snapped the bolt off when he was trying to take it off in the first place. and hes the king of over tightening bolts till they break.
Haha well I'm not that incapable. It's just the things that require to be done right the first time. Only thing I'm good at is putting windshield washer fluid in lol.
