quick question ( starter) need asap!
titanfan12
hey can anyone snap a picture of there starter I need to see were the wires go again.
Ive been doing an engine and tranny swap and have turned many bolts causeing me to forget. A picture of the starter with the lines bolted down would be great or you could tell me which ones go where. like the 8mm bolt should hold what and the 13 should hold what. Thanks guys
3 grounds on trans bell houseing ( so i dont forget lol)
the 2 fat lines go to the large 13 mm. the small one goes on the small stud, chances are you left the one bolt loose that you took off, so try the loose nut first of the 2 studs.
