steelholder
Hello all, I am having transmission issues and am getting code P0741.
Some of my symptoms include -
Hesitation accelerating (as if there's a blockage in the muffler) then a kick and a sudden burst of acceleration
At high speeds the rpm drops to 1-1.5k and when accelerating at high speeds the rpm has to "catch up" with where it should be around 3000 rpm @ 80mph and you feel a slight jolt.
Over all acceleration issues then the engine catching up,rpms going to 4-5k and the car just slowly accelerates etc.
I know this code involves the torque convertor, can it potentially be an easy fix, it mentions a circuit. Or is this a big job that'll require tranmssion removal? I need to get this out of the way to pass smog, if it is a big fix issue, can the code be silenced or removed? Thanks everyone.
