putting 22s on 04 gt2
504Quan
I have some 22/35/225 and I wanna put them on my car but people keep telling me they wont fit and its gonna mess up my tranny I need more input from actual grand prix owners on my car fax it says the tranny was overhauled at 110k I have 166k now
So much more comes into play here.
Like the offset of the rims, the kind of rims, the weight of the rim/tire combo etc.
The stock 225/60/16's are 26.6in in diameter, the 225/35/22 are 28.2in in diameter. That nearly 6% difference, which is alot.
So that will throw the speedo way way off. The weight of a stock rim is only 16-18lbs, I bet a 22's will be 35-45lbs for just the rim and add the weight of the tire and you are pushing 60lbs. The extra weight will stress the transmission alot more. If you drove like a grandma it wouldnt hurt it much but I doubt you'll roll around at putt putt speeds.
If the rim offset is low, they will rub........bad. With those tires, they will rub.
So if it was me, I wouldn't even run them.
