put it back together, now wont run
99gpse
i put everything back together, and when i turn the car on, it just revs to the limiter, and dies.... if you try to give it gas it just sticks at the rev limiter... and stays there, even with a little throttle. what is wrong? also the "trac off" light is illuminated, and wont go off..
i found it... er "The Car Guy" did (name of the local garage) i had a tie down for a wiring harness caught in between the upper and lower manifolds, and it cracked it.... $15 to replace from the junk yard... fixing it Wednesday... but thanks..
