Get the length checker and go from there. Especially with the OER lifters that only want like .005" preload iirc. Head gasket thickness, whether the heads have been milled etc can affect pushrod length. Worth the time to set it up right. I ended up needing slightly shorter pushrods, got them from Manton (3/8") Reasonable cost and excellent quality.
You will use it to get the proper preload, and then measure it with a caliper or similar instrument and that will be the length you need. Or better still, set it to 0 lash and measure (measure several or all valves) and then add your desired preload amount to the zero lash measurement. There is a writeup on the Zzp website iirc.
