I'm working through a P0440 issue that I've been putting up with for a couple of years. I'm finally tired enough of clearing the code to solve the problem.
I've already confirmed that the pressure sensor is good. I've smoked it and replaced the gas cap due to a small amount of smoke that appeared near the cap.
Here's where it gets odd to me and suggests there's something that I don't understand.
I took the purge valve out and tested it on the bench and confirmed that it opens when there is 12v applied.
I check the harness and confirmed 12v between the two wires in the plug when the ignition is on.
When I connect the valve to the wiring though, it does not engage. If I connect the 12v line from the plug to the valve along with a ground from the chassis, the valve engages.
How is this possible. In my brain, if I get 12v between the two leads on the connector, the valve should engage regardless of where it's coming from.
I feel like I'm not thinking this through properly, missing something, or don't understand the operation.
Can anyone tell me what am I missing here?
