Pulling engine.. ac comp issues
onsite
So got the two bolts off the front of the ac compressor and cant find the third bolt according to bill boost write up. Any help is appreciated!
Sent from my LG-LS720 using Tapatalk
How do i get to it? I thought thats where but i have no way to reach it.... bout to pull the bumper and rad and say screw it i can only contort my body so much
For what yr mines an 04 and only see 2 of the 3? Or am i somehow missing it
Would it be easier just to pull the lines and take the compressor with the engine.... ac isnt much of an issue in Michigan this time of year. I can recharge it later on
Hmm ill try again i feel like im going to break the thing into peices so i just left it alone
So i can get it now but my 15 mm wrench is to small? Tried a 17 and still to small. Any chance they put an 18 on it... still have to pick one up but why would this be the case?
Issue is the 3rd bolt behind the compressor between the lines and block. Which lines block from getting in with a socket. 15 mm wrench does not fit this bolt nor does a 17. So now going to try a 18 next. Reason i suggested taking lines off is from this being a pia i can only imagine what installation will be like
pop the 3 nuts off, as seen in the bracket here, on each end and one in the middle there. then just take the two bolts off the bracket to engine.
Ya it doesnt seem to look close. Ill get some pics up soon to compare. I did get it off and ended up being an 18mm. Now just need to get axles out and get the two exhaust bolts to loosen up for me.
Just to add , I went from a l67 to a l26 bottem end.
It's the same procedure for me both ways. Just remove the bolts holding the compressor to the bracket. Move out of way. Pull motor.
