Pulley swap question ------>>> NEW GUY
mjm06
Aight, ya im the new guy and im trying to learn. Im a certified mechanic and bodyguy so i have knowlegde of cars.
Ok so i was just on the zzp website. I just bought and 04 gp gt 3800 n/a. I was lookin at the pully swap but nothing to serious yet. I just have a few questoins.
1. What does a pulley swap intell.
2. What other modifacations am i going to have to perform for the pulley swap.
3. Is a pulley swap a good starting mod.
4. What am in going to gain from this.
Ok guys im a better bodyguy and painter than i am a mechanic so if you have any body questoins and you know alot about the motors hit me up we can help eachother out..
thanks guys.
love this site.
marcus
If you have a non supercharged car, there is nothing to swap. The swapping pulleys is referring to the pulley on the supercharger.
what pulley you talking about?
You can proably swap your tst for a 180. thats preety easy. Cheap mod..
Have you scanned your car.. Does anyone no if a ls1m work on a 04?
aight so the pulley questoin was a dumb one i should have used my common sense on that one.<----- idiot. lol
ok so what is a good mod for my gp then.
A PLOG (Powerlog Front Manifold) and a 2.5" or 3" Downpipe. Also I agree with the other's...a DIY FWI, a 180* T-Stat, and a tuned PCM (Intense-Racing, 3800performance.com) That should make for a PLENTY quick Non-Supercharged car. Past that you might want to look into a Cam or High Ratio Roller Rockers and Headers if you plan on modding any further than basic bolt-ons. Depending on your cash allowance, you can do a top swap or for more power than any supercharged car...a turbo kit.
IF the car was mine i would turbo it...
Plane and simply..
this is what i would do
1.180tst-- plugs
2. turbo kit from zzp
3. intercooler
4. slp headers
5 Tuned dyno run
am i missing anything?
Thats why i would do if the car was mine. From step 1 - step 5 i wuld do it like that.. 1-2 days..
i wuldnt be messing around with 14 sec car i would want a high 12's.... what i want only cost money LOL
Plane and simply..
1.180tst-- plugs
3. intercooler
4. slp headers
5 Tuned dyno run
I want to see how you're going to put a set of headers on a turbo build...
Beat me to it.
You have to get a turbo manifold setup. I bet he was gonna cut a hole in the crossover and weld the turbo flange to it :D
So again...follow what I said for a fairly quick N/A GP.
well i appreciate the help guys. I like where bluegtp91 is going. Where is the best spot to find all this stuff and what do you think im looking at cash wise. and that sounds like pretty much stuff i can do my self which i like.
marcus
Well the zzp website is good. They have the cheapest downpipes. Also look on 3800performance.com. And pfyc.com. They both have good sites and fast delivery. Tstat is cheap. Fwi is cheap if u do it urself. Go to the hardware store and buy some pvc and a aftermarket cone setup. Cheap. If u like the looks better then pretty much any fwi will do. Just don't go with k and n. Personally, I've bought all my stuff used except for my pulley. Just have to look around. I bought my downpipe used. Fwi used. Tb spacer used. Saves mucho bucks. The downpipe is a great upgrade. Ask some other people on here about which route to go on the dp. I have a 3" dp with no cat and u bend delete. It works great. Guess its just personal preference. Course urs is na so I'm not sure. Anyway hope this helps man. Good luck
Well...like superv6 said...
180* Thermostat (Local Auto Store) - $10 if that
Autolite 606's (Local Auto Store)- $10? maybe...
Custom Fenderwell Intake (Filter, $30; Intake parts @ Lowe's/Home Depot...maybe $20?)
2.5" Offroad Downpipe (ZZPerformance) - $119.99 plus shipping
Front Powerlog Manifold (ZZPerformance) - $119.99 plus shipping
ZZPerformance HV3 Upper Insert - $199.99 plus shipping
Tuned PCM (Intense Racing, Overkill Performance, or 3800performance.com) - Around $100 after you return your stock PCM to them
THEN...if you still want more out of your car...sell the PLOG and DP...get headers. Headers really depend on your budget and can be had from $300 or so to around a grand. I have Pacesetter's and love them...once you get past sealing up all the little leaks and such they are great for the price (I got mine with the 2000* Coating for about $400 and something brand new back in the day).
You can either take a couple routes here.
1) Turbo/Intercooler Kit
Some guys that know more about turbo-ing the L26's can jump in here if they'd like...I think TDC is pretty knowledgeable about the turbo setups in the 3800 powered cars. I know there are Cartuning, ZZPerformance and maybe someone else that I can't think of right now...
2) ZZPerformance High Ratio Roller Rockers and Headers
Very good driveabilty and gains are close to that of a smaller cam upgrade without the hassle of opening up the motor and not sacrificing mpg's. They will also really help on your top end power since the 3800 is lacking that department from the factory anyways. ZZPerformance sells 1.90:1 Modded Stock Rockers, but you will need upgraded valve springs if you plan on shifting higher than 6,000rpm's. You can get stock LS6 Corvette Springs and Retainers from GM. 1.9 Modded Rockers from ZZP are $329.99 plus shipping.
3) Cam and Headers
Again, MANY choices here and you can get even a custom grind cam from PRJ Performance but since you are not going real balls to the wall that won't be needed but incase...he does them for $500 IIRC. ZZPerformance sells the GT line-up of camshafts for the 3800. They offer the GT1, GT2, and GT3 Cams. The GT1 is the easiest going of the three and you'll see gains with the right tune of 20-30+hp. The GT2 is more aggressive and will require upgraded valve springs. It is also a higher powerband cam where you'll be making power up to 6,500rpms. Upgrading the pushrods is recommended but not NEEDED. You'll see gains anywhere from 25-35+hp depending on your other mods. Then there is the GT3 cam. ZZP Says this about their GT3 camshaft upgrade:
"The GT3 cam was designed for use with ported heads and added displacement. Upgraded pushrods are recommended. For use with stock heads mod'd retainers are required.
This cam was designed for naturally aspirated applications using our stroker kit. For use on a highly modified 3.8 liter, shift points will need to be 6800 - 7k for maximizing the powerband. It will set the P0300 code unless programmed out of the PCM. Idle is lumpy, especially with headers. Gears and a higher stall torque converter are recommended.
Look for gains of 30-40 HP depending on your car's current configuration."
Then you have the same kind of options from INTENSE-Racing.com - G8, Grand Prix, Bonneville, Regal, L67 3800 Supercharged Performance Products.
Hit them up too. Hope you can get a bit of knowledge from this read ;)
