Pulley setup.
00SilverGTP
Ok so I know its probably been asked before......buuut......
I am new to GTPs. What is the advantages to running a 3.4 or 3.2 pulley over stock? I see its a common mod.
I am not very familiar with superchargers.
I also see "running a 3.4 and supporting mods." What exactly are the supporting mods?
Long story short.
Motor doesn't flow well.
Has a high RPM cylinder filling deficiency.
You need to increase flow.
Then you can spin the blower faster.
Motor = air pump.
More air in, more air out, more power.
Good times.
If you're stock. There's NO advantage running a smaller pulley.
In fact your stock pulley car probably already knocks on the order of 4-6* of timing reduction at wide open throttle.
Smaller pulleys spin the blower faster, making more boost. More boost without flow mods = more timing reduction and possibly chipping a piston.
Matt put it as plainly as it had to be put. Our motors already don't flow enough for a stock pulley.
blower spinning faster does not mean more boost.
It means its blowing more air into the manifold.
the motor not being able to keep up results in a pressure buildup in the intake manifold that we call "boost".
Ok, I am only planning on a CAI, and exhaust for mods at this point. I just dont know if I should bother with a smaller pulley or not.
Awesome.
Word of advice: Transverse 3800's sound poopy all the time.
So have a resonator/glass pack in the stock location and two turbo mufflers. Nothing louder or you'll most probably regret it.
Awesome.
He is doing headers, cat and magnaflows. I dont want it much louder than stock, just more free flowing and a little more aggressive sounding. I have noticed a few 3800s around that have that almost chugg mixed with fart sound I am prepared for to have a bit of that. But I definitely dont want to wake the neighbors when I fire the car up at 5am to go to work
If a resonator is needed still we will add one
SD headers with no cat, no res, and gutted mufflers sound like some pissed off hamsters and a 5b bag of rocks in a blender.
FYI. lol
