pulley help anyone close to york pa
Stock pulley. Who cares about the stock pulley?
This is true. Can I remove it without damaging/bending the shaft? If so, I could care less about the stock pulley. Then I could just remove the supercharger belt until I get tuned.
Anyone ever use a 3 arm puller to remove the pulley? Could I just use that? If so, how can I press the MPS hub on? Rubber mallet?
LOL rubber mallet.
No.
Take it to a machine shop that has a press. They can remove and install the pulley/hub if need be.
LOL rubber mallet.
No.
Can you just install it with a press? But setting the snout on the flange? I would be worried about cracking the snout. Maybe I will try it.
Aaron, if you want to try it, I can try here at work. No guarantees, but our largest press is 500 tons. I think that should do something!
