pulley belt from zzp
nemesis
i bought a belt from zzp and after it arrived i noticed it was a napa belt. i never like anything made by napa, but is napa a good belt? i always used gatorback.
I did the same thing last spring. I installed the belt and never had any trouble with. I only had it on for a couple months though. I thought I read somewhere that the gatorbacks caused slipping issues?
For the supercharger belt, gatorback is not favorable. Many people have had many problems when running a smaller pulley and a gatorback belt. They work fine for the accessory side, but they tend to slip sooner on the SC pulley.
As for good belt, most consider the NAPA/Gates belt to be one of the best. I run the Gates belt and they work great. I wouldn't worry about it at all.
Ran both when I had a 3.0 with no problems. IIRC it's under the 2.8 that you may have a problems, but this one of those doesn't really matter things. Luckily the belts are cheap enough, if one doesn't work out for you try the other.
