intrigue98
I acquired this 97' GTP from a relative last year. It was not taken care of whatsoever over the years and I wanted to bring it back up to par. The transmission lost 3rd gear, the engine was leaking everywhere, the suspension was shot, and the brakes barely worked (warped rotors, 60k+ on the pads). Just wanted to share some pictures of how the car looked before to how it looks now along with all the things I did to it along the way. I'd say its about 90% complete with body work/built trans being the last two things on the list.
Current Mod List:
Exterior:
- Projector headlights
- Blazertech fog lights
- Tinted Tail lights
- Badge overlays
- 17" GTX Wheels
- SLP Gen1 spoiler (needs to be installed)
Brakes/Suspension:
- KYB AGX struts
- Vogtland springs
- Upgraded sway bars/endlinks
- Poly bushings
- F-body brakes
- Goodrich stainless brake lines
Engine/Trans:
- stock trans w/ shift kit and aluminum drain pan
- replaced all gaskets down to the long block
- MPS
- HS 1.9 Rockers
- SD headers w/ SLP cat
- Corsa Catback
- Custom Water/Air IC system w/ Meziere pump, aluminum reservoir, bar and plate heat exchanger/core (2 gallons total in system)
- Gen V
- N* throttle body
- CAI
- Ported/Polished LIM
- PRJ rails
- 42lb/hr green top injectors
- Billet Aluminum valve covers
- Poly motor mounts
- 99+ coolant bottle
- 125 amp bonneville alternator
- etc...
Before: (After a thorough cleaning :lol: )
After:
Current Mod List:
Exterior:
- Badge overlays
- 17" GTX Wheels
Brakes/Suspension:
- KYB AGX struts
- Vogtland springs
- Poly bushings
- F-body brakes
Engine/Trans:
- MPS
- HS 1.9 Rockers
- Corsa Catback
- Gen V
- N* throttle body
- CAI
- PRJ rails
- Poly motor mounts
- etc...
After:
