gtp239
I got 2 used key fobs for for my 98 grand prix and cant get it to program to the car i followed these instructions i found
Remove the ignition key from the ignition lock cylinder.
Close all of the doors.
Remove the MALL PGM fuse from the fuse block.
Insert the ignition key into the ignition lock cylinder.
Turn the ignition to ACC. The body control module (BCM) will perform the following in order to identify the type of BCM installed in the vehicle:
Flash the seat belt indicator 1, 2, or 3 times.
Chime 1, 2, or 3 times.
Turn the ignition to OFF, and then back to ACC within 1 second. The BCM may begin to chime and flash diagnostic trouble codes (DTCs). If the BCM has stored any DTCs, refer to Diagnostic System Check - Body Control System in Body Control System.
Open and then close any vehicle door. The BCM will chime in order to confirm that the programming mode has been entered.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for approximately 14 seconds.
Important
After approximately 7 seconds the BCM will chime once to confirm that synchronization has been completed. After approximately 14 seconds the BCM will chime a second time to confirm that the programming has been completed.
i get into programming mode then it starts a chiming at me maby a code? the chimes are 12348 does anyone know what that means?
my steering wheel air bad clock spring is broken and dosent work would that causer this to happen and not let me finish programming
Important
