problem with engine light?
CheeWee
problem with engine light and code reader connection plug.
will not read the codes. wonder if it has a fuse? got a zzp PCM might that be the issue?
and engine light keeps coming on and of with the car choking at WOT...
it will bogg out when its reaching high rpms and i dont know if it can be a O2 sensor or Fuel filter?
Help lol :th_scratchhead:
Hmm...another ZZP PCM Issue perhaps? Maybe now everyone will see what I've been babbling about ;) I lost a motor to one man...I know how you feel. Flashing SES light is most of the time a misfire...pull the pulgs to see if any are bent...you might be knocking with that 3.4" and not enough flow mods. Try checking plugs, wires, coil packs, and the ICM (Ignition Control Module...the aluminum part the coil packs sit on)
yeah cause it come on and off every so often imma give it a try see what the issue is. im just tired of the issues left and right lol
thanks for the info man
