Pressure control solenoid?? HELP
gtpman
car sits and sounds like the power steering pump or s/c is whining but its coming from the tranny and when it throws the code P1811 it acts like it doesnt know what gear to be in.i use my aeroforce scan gauge and clear the code the noise will go away and its all good. can anyone help.
does anyone have an internal diagram of the transmission where the solenoid is i need one real bad. any advice would be soooooooooooooooo appreciated because i am a single mother with 2 teenage children and no way to work because of this problem. I need a diagram really really bad! Thanks so much and god bless you all!
Once you lower the trans out of the car enough to pull the side pan off, it's the 2nd soleniod down on the left. Or...the largest soleniod in the trans.
