Power steering pump issue
garret lamay
So I had one of the power steering pump bolts snap off in the block. Would it be easier to pull the engine so I can use a snapped bolt remover or to drop the subframe. I am thinking drop subframe cause I only need a couple inches to get to the hole. Next question how do I drop subframe using only floor Jack's and Jack stands cause that's all I have to use.
id take the alt and its bracket off, then use a right angle drill on your extractor tool.
cant ses lowering the frame being of any help.
