Power Steering Leak
robinsone
Looks like I have a PS leak from the plastic reservoir. I assume the PS pump and reservoir are one unit so its a total replacement but wanted to confirm. Let me know, thanks.
Yep, just grab yourself a GM pulley removing tool and swap out the pump. Or hit up a Jy and save some money and find one that isn't leaking. When you go to swap it out don't forget that the rear knock sensor wire harness is attached to the pump so be sure to remove it before you remove the PS pump/res. or you'll be having a lot more fun that originally thought.
