Power gains
drenolov
What kind of gains could I expect after add down pipe,pcm cam and torque converter to my l26. And what other adds do you recommend for a goal of 400 to 500 hp
400 at the crank? Yes. E85, cam, tiny pulley, maybe intercooler. Very doable on a m90 setup. But turbo will make more and probably cost the same, maybe less.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Ok so I'm Wreck-It Ralph going Turbo
trans fails at 300-350 hp. anything more you really need a 3 to 4000 dollar tranny built. lots of expensive hard parts are needed.
TEP, they are a sponsor here. have a banner at top the page. triple edge performance. many many many guys have ordered built trannys from them.
This is mostly true. But not driving like an idiot goes a long way. I've been around 300whp for over a year and only a shift kit in my stock trans and it's still doing great. I might be on borrowed time, but if you don't go WOT every shift you make, you can make the stock one last a bit with some general maintenance
^^^^^your driving habits will for sure dictate the tranns life span. im likely close to 300 crank hp on a stock tranny with just a shift kit myself, its holding fine with 150,000 on it.
its when you add a cam, or a turbo stuff starts to break. the flex plate and input shaft are the first victims. stock flex plates crack under stock HP.
Chrsmi1 are you running l 67 or l36 what upgrades do you have
you must be on tap talk, its in his sig
Comp G. E85, 3.0, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
my weak ass list next to his lol
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, 3.0, FSIC, 42 lb injectors,
Probably not too much of a difference between me and Scotty honestly. Cam adds maybe 20-30 hp over his rockers and his intercooler is the equal to my e85. I've dynoed mine a few times on this setup and a 3.0 and had as high as 307whp. I could probably add a catback exhaust (I'm still stock there) and go to a 2.8 and gain another 15 or 20 at the wheels. But as is its pretty quick.
What are the 3.0 and fsic what #s are you putting out
Ok so you don't have a lot of mods other than cam and e85 did you change any thing to run e85 I was have sleep and put e85 in my car and it locked up
