Power drop!
YoungGTP
okay its been doing this for awhile and ill explain. ill be cruising on the highway or interstate either manual or in criuse and ill start to go up a hill and i wont excell much and ill get to about 2k the engine starts to feel some grunt and falls down to about 1600 and it kinda jerks like the trans slips or power is lost. now i have a brand new trans and i took it in a week after to get it checked on and its fine. i do have a very loose alternater with stripped out bolts and i snapped lower bolt. i need help bad, it irritating and i know its not good.
Did you have your trans rebuilt, get a junkyard unit or a brand new unit?
Also did you notice any difference at all between the old and the new tranny?
the trans was rebuilt by aamco but they had new internals and the case was new. the only different i felt was a crisper shift due to new clutches
I had this problem it turned to get "The fuel pump, cam sensor, and crack sensor" you may want to check those ?? but i would start off by first fixing the alternator
thanks. but yea my buddys dad is gonna do it and its gonna cost around 350 so im really not excited to do it
